iwillwait4u
- Aug 30, 2011
- Churdan, Iowa
- 13 xtx nytro stage 1 turbo
Well hard to watch but my wife tipped my nytro on its side
But thankfully she was not hurt!!! So... flashing code 30 no oil pressure. My question is how long do you normally have to wait for the oil to run back where it is suppose be? I waited 2 minutes and still threw code 30 then another 2 minutes and still code 30 and then 3rd time no problems good to go just wondering for next time if there is a rule of how long to wait and hpefully no damage was done?
mx1500
good question. when i got stuck vertically in a drift i rolled it down, and oil leaked out oif mine. and the code came up i waited 5 m,ins, and putted around and the light went off.
Supa Dexta
How long was it on its side and how much oil did you lose? Check your airbox.
Couple minutes should be sufficent
iwillwait4u
- Aug 30, 2011
- Churdan, Iowa
I flipped it back over as quick as I could. I am thinking less than 2 minutes. Thankfully she did it right be side me when I was on her sled.Supa Dexta said:How long was it on its side and how much oil did you lose? Check your airbox.
Yamatario
- Jan 8, 2009
- SW Ontario
- 2018 LTX SideWinder
2015 Viper LTX DX
2009 Nytro XTX
iwillwait4u said:I flipped it back over as quick as I could. I am thinking less than 2 minutes. Thankfully she did it right be side me when I was on her sled.Supa Dexta said:How long was it on its side and how much oil did you lose? Check your airbox.
Time for a roll over valve kit. Just finished installing one on mine.
Bahr05
- Dec 18, 2010
- Medford, WI
- '09 Nytro XTX
I just changed oil in my sled, and i drained all the oil out, and put the new filter on with no oil in it. I only put oil in the tank, none in the engine. When i started it, i didnt get any codes. Makes me wonder why you are getting codes from tipping it over. There's oil in the engine, so your oil pressure should build alot quicker then mine with no oil.
iwillwait4u
- Aug 30, 2011
- Churdan, Iowa
Where do you find your roll over kits? I think it is a great idea!! Thanks for the idea!!Yamatario said:iwillwait4u said:I flipped it back over as quick as I could. I am thinking less than 2 minutes. Thankfully she did it right be side me when I was on her sled.Supa Dexta said:How long was it on its side and how much oil did you lose? Check your airbox.
Time for a roll over valve kit. Just finished installing one on mine.![]()
Oftracing.com. mine was used 2 3 times last weekend up in the mountains worked awesome.
brs077
- Mar 8, 2005
- Cobleskill, NY
- 2013 Yamaha FX Nytro XTX 1.75
I've got it on mine, was simple to install, and after my fiance had her Phazer rolled on her and we had to go for a ride for a quart of oil, I'll be putting one on hers as well...
Yamatario
- Jan 8, 2009
- SW Ontario
2015 Viper LTX DX
2009 Nytro XTX
I got mine from Four Stroke solutions. It also will turn off if left too, long so it doesn't kill the battery.
Check it out with this link.
http://fourstrokesolutionsllc.webs.com/ ... erovcm.htm
iwillwait4u
- Aug 30, 2011
- Churdan, Iowa
Thanks to all for all your help!!! Roll over protection is on its way!!
