Apex rpm ?????
I've seen 10,500 since mile 1 and still 10,500 with 500 miles. I did see 10,800 to 11,000 on a very frozen trail and temp was around zero and it was only that one time. Clutching is stock.
Rick
When I was in MI a couple weeks ago I ran down a desolate road and for a while a saw 11,500rpm, that was wot for a while w/ 600+miles and the speedo was maxed @124mph :D
I don't know-I know this is more r's than anyone else is saying theirs go to, but thats what I saw- did it a couple of times just to verify and about the same each time--this has to be almost dangerously high r's no? :?: :?: :?: :o| :o| :o|
If you ran 11,500 you probably have grease on your belt from the secondary. Check behind the secondary to see if grease has spit up.
1fast1 said:
peak power is @ 10,200 for stock apex/attac
That is kind of where I will want mine to end up. Some of the guys seeing over 10,500 my pull harder if they clutch between 10,100 and 10,500.
