Turbor
- Apr 16, 2008
- mirabel,quebec,canada
- sidewinder
anybody can tell me the tach wire color? from what ive seen, its looks to be the blue/yellow, but if im right and god knows i hope im wrong, that wire comes straight from the ecu and drives other stuff also. Now, my problem is we installed a stand alone management system on my sled and neede to modify the flywheel to get it to work, so i now have half less teeth on it than before , so my tach reads half of what its supposed and my headlights dont go on at it idle, only when i rev up the engine... i know whats the wire that comes out of the crack sensor, and thats the onle id like to double the pulses, but its only a 1.16volt signal, and i cant find a pulse doubler for that kinda low voltage. so im thinking of doubling the pulse right before the tachometer and plug the sleds lights on an ignition power. But i need to find the tach signal wire gefore the tach tho, thanks!
