The Tors is there to stutter the engine if your throttle freezes. It knows when the thumb throttle is closed and if the cable is still pulling the engine throttles open it thinks you have a stuck cable and stutters the engine so your sled doesn't take off on its own.
Since you have a bar riser on your sled your throttle cable is now being pulled tighter then before and is creating a legitimate signal for the tors to activate.
You need to loosen your throttle cable adjustment to create more slack in the cable and your problem will be solved.
