Mudvayne
Hi guys just purchased a new to me 2007 mcx turbo apex long story short the guy never rode for a long time it needed a battery so the day I purchased it we used a jumper power pack started and ran fine. I purchased a new battery installed and test started it a few times again ran and sounded perfect, this was about a week ago. Today I tried to start and no cranking just an exclamation and check engine on the dash when I turn the key any help would be awesome I'm super baffled here I have check all fuses and obvious stuff.
Thanks.
Thanks.
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
Battray is mostly likely low.
Mudvayne
APEX 06 said:Battray is mostly likely low.
I wish it were that simple but its been on the battery charger all day also tried boosting it. This is on a brand new yuasa battery that I initially charged as per the directions! :/
APEX 06
- Apr 30, 2009
- Sheboygan, WI
Is it giveing you a code #
Mudvayne
Got it running appears to be the starter relay wires on top are corroded jump the red wire to starter and fired right up still wont start with key but clicks so must be that relay. Hope it helps someone.
Super Sled
- Feb 25, 2009
- Summit X
Good job trouble shooting that issue, dude!
