Purchased a 07 apex SE today Need help rough idling
furg69
st.anthony newfoundland
Just purchased a 2007 Apex MTN SE 162. It fired up fine in the guys garage where i puirchased it. I did try to move the sled from all summer not being started, Now it barely starts and if it does it's really roughidling. Im guessing i foulded the plugs maybe ? Never had an issue like this with my Fx Nytro. My guessing is, do i have to change the oil now if i fouled the plugs ?
Was there any type of fuel stabilizer used during storage? I would pour some Sea Foam in the tank, top it off with premium and run her in this case.
You might be able to get by with just taking the plugs out and cleaning them. I fouled the plugs on an 08 Apex once where I couldn't even start it. Took them out and wiped them down good, reinstalled and it fired right up.
Changed the plugs, Sled fired right up fine. Does sound to need exahsut gaskets replaced and also has low coolant. Hope the sled isn't buring it. or leaking headgasket.
