DelgatyXTX
I've heard of a few guys putting Apex guages on their Nytro and I found a guy near me that has a couple for sale. Obviously I'd have to fab up a mount but is the connector the same and is it compatible? Or does it take alot of splicing?
Any help is appreciated,
Thanks!
Ryan
Thanks!
Ryan
radianguy
- Jan 1, 2007
The Apex gauge won't work, you need the FI Vector/Venture gauge. The gauge from the FI 3 cylinder is plug and play, you do need to add 1 wire if you want the clock to work I believe??
natedawgedog
- Feb 5, 2011
- DLG, Ak
- something from 2019!
apex gauge will not work. EFI Vector gauge will though the only thing that will not work with the gauge is the clock, with minimal wiring you can get the clock to work just fine... search "vector gauge in nytro" and you will find a whole writeup on the subject
DelgatyXTX
Thanks for the help. I will have to find out what year Vector it's off of to see if its FI or not.
Thanks again!
PS: I had tried a search but didn't find anything... I have bad luck with the search function on forums. I did find the thread by searching google however.
Thanks again!
sorenson1610
- Dec 11, 2007
- Rothschild,WI
- www.contrx.com
The link is in the sticky nytro faq at the top of this section under electrical
