m.schuey7
- Feb 4, 2014
- Colorado Springs, CO.
- 2011 Yamaha Nytro XTX
Need to buy a stock ECU for my 2009 XTX. I heard somewhere that the later model ECU's had a fix for the low power heated grips in the earlier models?
m.schuey7
- Feb 4, 2014
m.schuey7
- Feb 4, 2014
Looks like all are interchangeable, still wondering if the later model units will repair the weak heated grips on my early model.
DirtFarmer
- Aug 13, 2017
- Galloway, NJ
- 2009 Yamaha Nytro R-TX SE
From what I have read the 2012 & up we’re not much better. Yamaheater seems the way to go or invest in real good gloves and gauntlets.
m.schuey7
- Feb 4, 2014
Copy,
Thank you !!
Thank you !!
Dr. FeeLGooD
Being an unbeliever, I installed yamaheaters and RSI grips at the same time on my 2010. Found out that was too hot. I took the yamaheaters off and my RSI grips do the job alone. Yamaheaters or RSI grips, or a reflash on the ECU are your options imo.
pro-man
- Aug 30, 2017
- Lwr Michigan
- vmax-sold
Industry leading 4 stroke engine technology with heated grips made by Fisher Price! Thanks Yamaha.
The heated grips did get better in 2012 not sure if that was do to programming in the ecu.
Hooray!
- Aug 12, 2017
- Maine USA
- 2009 Yamaha FX Nytro XTX
1998 Yamaha VMAX 700 XTC
Yamaheaters work well on my 2009... Never on high...
herndonp
- Nov 28, 2012
- Freedom,NH
- 2012 Yamaha Nytro XTX
I have the 2012 and grips are fine. Very rarely turn them all the way up except when below 0 deg F. Then up initially then back off alittle.
Pete
Pete
