I need a yamaha key switch for an obsoleted part on a bike. It is a simple double pole single throw set up. It connects two wires when on and disconnects another two. When off it disconnects the first two and connects (grounds the cdi) on the other two. The starter relay has it's own button so it's not in the key switch. Maybe an early Phazez or some other 2 stroke app. The relay contacts can be there and just go unused.
Roadrider said:I need a yamaha key switch for an obsoleted part on a bike. It is a simple double pole single throw set up. It connects two wires when on and disconnects another two. When off it disconnects the first two and connects (grounds the cdi) on the other two. The starter relay has it's own button so it's not in the key switch. Maybe an early Phazez or some other 2 stroke app. The relay contacts can be there and just go unused.
So you are looking for a key switch off an old sled?? or you are looking for some help?
If some one knows the schematics of some of the old
2 stroke sleds that may work for the bike. double pole,
single throw. No starter relay position needed.
My terminology might be off, a double pole double throw toggle switch would be needed to replace it if it were to be used.
It appears the most common of all yamaha 2 stroke
sled switchs will work. Has a start position that is not needed but even the wiring colors are correct.
I may have an older ignition for a sled.. I have to just dig around... been busy working on site issues.
They are only 35.00 new with the keys. Already ordered. Thanks though. Took me a while to dig up
schematics on the net. Couldn't go out and buy manuals until I hit on one that would work. lol
Roadrider said:They are only 35.00 new with the keys. Already ordered. Thanks though. Took me a while to dig up
Cool
