attack 20 track
heres a pic
Cat uses small outer "nubs" on their tracks. The powerclaw is the same way but it has nubs in between the ones you have pictured. If you get a powerclaw and have Avid drivers, the "in between" nubs need to be clipped off.
you have rows of 6 nubs going across your track, if you have any in between, clip them off, otherwise it is not the lugs that are causing ratcheting. Are both the track and drivers the same pitch?
