rxwhopper
jusr wondering what it could be? at about 30 miles per hour and up it has a wine sound coming from it. i put in new bearings in the case and it still does it. the secondary bearing is fine and so is the lower driveshaft. only thing dufferent is the extrovert drivers. any ideas. seems to do it worse on acceleration and when you let off
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
is this the dreaded exhaust drone we all talk about?....sorta makes your ears ring with a harmonic type pitch?
it drives me nuts,and i MUST crank my mp3 player!
Dan
Dan
Yamaholic22
Vipers make the same sound. Most people have come to the conclusion that it is mostly the chain tensioner making noise in the case.
Bone Daddy
exhaust drone between 35 to 45 mph. no cure yet but maybe soon.
rxwhopper
deffinetly not exhaust. more like the chaincase or gears. mine seems to be worse then others.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
rxwhopper said:deffinetly not exhaust. more like the chaincase or gears. mine seems to be worse then others.
wow,i dont see how anyone could hear the gears with the loud exhaust and drone...lol.
i just crank my tunes and ride now...lol
Dan
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
rxwhopper,
the more you gear down in the chaincase, the more whine you'll notice. Think of the RPM the reverse idler gear is turning on that little needle bearing! Did you gear down from stock? I notice it more when letting off with the 23/40 gearing, over the stock 23/38 gearing.
