LuvMyWarrior
HI Guys,
I have an 07 Attak GT and when I adjust the compression with the electronic thumb control I cant tell a difference from the highest setting to the lowest. It shows on the control panel that it is adjusting but I cant feel a difference. I have the big boy spring. I dont think it is a cable issue or it wouldnt show up on my gages? Any suggestions or anyone feel the same way? I thought I would be able to tell a big difference but cant tell a difference at all. NONE.
Thanks!
Thanks!
Soldier'spapa
- Mar 21, 2006
- Naperville, IL
- 2018 Sidewinder Ltx LE 50th Anniversary
I ran my attak GT last season with the std spring ( I weigh in at 200#.) I must say that I could feel a change when I adjusted the EC. This season I had the shocks revalved from Hygear and had them add ther dual rate springs. Wow! What a tremendous improvement! I usually ride it in the softest setting but when I turn it up I can feel quite a difference.
Have you adjusted the sit in? Perhaps you might want to have the shock revalved.
LuvMyWarrior
Thanks for the feedback! Anyone else have this experience?
tuner
I can't tell the differance either. Is it normal to revalve the shock already?
johnnysrx
I drove my friends attak who is a lot lighter then me and when I got on it, it was botteming out pretty easy. So I cranked up the setting and it didnt bottom for me so I "did" notice a big difference. Thought it was vey cool
NY_Nytro
- Dec 24, 2004
- Grand Island, NY
- www.gi-snowmobiler.com
tuner said:I can't tell the differance either. Is it normal to revalve the shock already?
Revalve not rebuild. Revalve a shock was it's too soft or too hard in its stock form. Rebuild when a shock has lost its charge from use over time.
