Attak Mono Question???
Heritage
Northern Wisconsin
I find my mono is a tad soft for my liking/riding style...I am 220 lbs with my gear on. I have found many aftermarket shock/spring combos...I would like something inexpensive, and easy to do. Tell me what worked for you.
BTW just got my yami 2011 assesory catalog...couldn't help but notice the electronic olin...no price..is that easy to install??? worth it??? is it plug and play (easy to put in )??
Anybody else wondering if that new fox float would work in an attak??
Or if it would be a good option??
soft
There are companies out there that offer heavier springs..But you can save your money and fix it easily...Pull the mono shock out and there are 3 preloads for you spring...You take the spring off the shock and slide the spring up from the collar it sits on...Under this collar there tere is a snap ring...Move it up to the third position and reinstall all...At it lowest setting now it will handle 230 lbs no problem...
Re: soft
Ty... I will try that.
