AttakDog
Hey just wanted to let everyone know to check some things on their Attaks. I am installing the extrovert drivers and a new track and while I had it all out I found some issues. First the rear tunnel crossover tube rivets were loose to the point of letting the tube rub on the chassis, which if let go would rub a hole in the crossover pipe. Also 1 tunnel protector bar was also broke loose which could have caught the track. I had to re-rivet all this stuff (PAIN IN THE A$@). This is with 5000 miles hard riding on this sled (06). Just wanted to let all know to check. I still need to check the 05 RX1.
Yamahammer485
Too bad that happened to you.
I am going to check mine soon, nice catch!
attak-d
- Sep 20, 2006
- North Freedom,WI and Iron Belt,WI
Thanks for the tip I will have to check that when I put in my rear heat exchanger.
tryanATTAK
- Mar 6, 2007
- Scotts, Michigan : Southwest lower
Thanks for thee heads up. Gene
AttakDog
The RX1 has the same issues
