blue06
what rpm do your sleds run at around 60mph. mine runs at 8000 is this normal or too high. i find it high when riding between 8000-9000rpm. i know they like to rev just making sure this is normal.
kviper
- Nov 7, 2003
- Oakfield WI
- 2012 MCX Turbo Apex
Cruising RPM will vary a lot depending on condition's You will run less cruising RPM on harder cond's and more RPM in softer stuff but i would say 8,000 ish at 60 is in the ball park. Driven clutch setup will also effect cruising RPM. If your WOT shift RPM is where it should be you are probably fine. kviper
blue06
wot shift is fine, fuel mileage is good. just making sure that's where they run, leaving for a 1 week trip so making sure everything is ok. thank's for the quick reply.
tttario
blue06 said:what rpm do your sleds run at around 60mph. mine runs at 8000 is this normal or too high. i find it high when riding between 8000-9000rpm. i know they like to rev just making sure this is normal.
All I know is mine idles at 1500 RPM and WOT is 10,700 RPM. Nothing else matters.
yamahahaapex
RPM's on my Apex MTN is 8000rpms@80km/h
Now thats high
Now thats high
