ATTAK SPRING TWIST
SharkAttak
East Falmouth, Ma.
the o6' attak is set at a 3-3 twist, has anyone tryed a 6-1 or something other that, can you share you results, thanks
You only need to tighten the wrap if your belt is slipping in the secondary. Most of the time you can feel it or look for a darker area at the top of the shives of the secondary clutch. If it is slipping there will be a dark residue from belt poop on the shives. The only time you might want to tighten it up is for grass dragging.
