live2ride
- Feb 16, 2012
I was riding the trails yesterday and shut my sled off to take a break. When I went to take off I turned on the key-let the system prime and hit the hey-nothing but a very soft click. Not the king of click that you get when the battery is too weak to roll it over. More of a relay click- I ended up rolling the cluth about 1/8th of a revolution and it started right up. It has done this too me about 6 times now. Not every time but most of the time.
Anyone have this issue before?
Replace your starter relay.
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
x2 had same prob it was all green when i took it apart.slimjim2525 said:Replace your starter relay.
gas n go
Same issue on my buddy's 08 apex. Switched the relay from another sled that we knew worked and it still does not work. Any way to bypass this and jump the starter to check the starter or is there a way to test the relay and/or solenoid?
Check your main ground from the battery.
1) Jump the starter, jump the big relay terminals
2) Power up the relay straight from the battery through the small terminals
3) check the main fuse and ignition fuse
4) check the main switch
5) check the connector from the main switch.
That's as per the manual.
There is also the kill switch (red button)
There is also a diode shunted between the control wires on the starter relay.
I would also check the ground on the main switch (black wire)
