Skydog
Well i now have 800 miles on my Rx1 with a rear mount at 12psi with pump gas. Only mod is added one extra head gasket. Sled ROCKS!
Ran on the trials at 5-6psi 12 WAY to much! Left the 400 jet in the charge tube. Little rich on low boost but ok to live with.
Put some SLP P.P. on they rock on and off the trail love them! (need to shim the back)
The sled did not miss a beat all week!
I turned the idle air screws out 3/4 more of a turn from stock. This took care of my high idle. But made the sled a pig to start after it sat for about 40min or so. Had to hold the gas to the bar and spin for about 3-4 sec. So i will be putting them back.
Thank you Skydog
P.S. Did some water skipping at Baurs damn in Wisc!
Ran on the trials at 5-6psi 12 WAY to much! Left the 400 jet in the charge tube. Little rich on low boost but ok to live with.Put some SLP P.P. on they rock on and off the trail love them! (need to shim the back)
Thank you Skydog
Skydog
1000 miles at 12 on pump still great! No blow by or coolant problems!
Idle air screws set to 2 turns out works great there. I was on Lake Gogebic so i am sure i put the motor to the test!
Skydog
Skydog
Silverbullet
Sounds like you are having a GREAT TIME with the bender turbo...I loved mine but she was just a little to loud for my taste
