Thomas800
- Dec 17, 2004
- Fort St. John B.C. Canada
- www.snowmobiledragsters.com
You could start by putting a little more pressure than what you plan on running for boost. I found though, that when I backed the pressure down I got more bubbleing. The volume of my leak was great enough that the soap would blow clear of the opening and not form any bubbles until I backed the pressure nearly right off.
Like Travis, I like the billet tees. I have used the spools inside the rubber tees successfully, but eventually got bit by the split tee. I build my own billet tees on my lathe, but for the price the MPI ones, they look pretty good. One other though, if this is a new install, is it possible that you got to much epoxy in #2 carb vent and plugged it off? Maybe check for communication to the bowl from the tee.
MartyRX1
Thanks for the tips guys. I'll work on it this w/end and give you an update next week.
TurboJamie
Ever figure this one out?
MartyRX1
I'm just waiting for the billet T's to get here.Hopefully they 'll do the trick.
Marty
Marty
