hypertxer
i bent my two right a arms so i found a guy right near me that had a set for a apex er i have a rtx so i put them all on and the er ones are differant wtf. i dont know what to do now. the shock mounts are off by 3 inches is there anything i can do. i wish i knew this in the first place. i guess i have to find 06 rtx ones huh lol
number1kyster
- Dec 10, 2004
- Vermont
- 2018 SW RTX SE
They are the same. I would say that you bend either your bulk head or your spindle!
Kevin Garceau
sounds like his day just got worse
Maybe you put your A-Arms backward...
hypertxer
no the shock mount is the only thing everything else is mint. the shock mount is off
Crewchief47
- Jan 16, 2006
- McGregor, ON Canada
- 2008 Nytro MTX 45th
Maybe the shock shaft has just enough bend in it to not fully extend? Unbolt both shocks and meassure eye to eye.
LazyBastard
Arms are definitely identical, unless you swapped with the 03-05 arms... If thats not the case, then you bent your shock.
hypertxer
i took a measurement from the a arm bolt to the bottom of the a arm where the shock mounts and it was 2 inches off from the stock a arm. i dont know what year or model sled they came off but they were red. the sled was burnt. are all the a arms the same attak apex all.
Tom-RX1
you got 03 -05 a-arms thtas the difference between them .
Tom-RX1
Tom-RX1
hypertxer
ok i have the apex mountain ones i think my upper arms have the braces that go between them like the mtx ones and it looks like the shock mounts are differant to
hypertxer
are the mountain a arms differant
LJ 452
I believe they are narrower.
BADSLED
- May 13, 2004
- Syracuse, NY
- 2025 Sidewinder XTX LE EPS
2012 Nytro MC Xpress 270
Mountain arms are narrower.
