rowdy_1851
i went out yesterday and hit a big skidder rut which sucked me in. when i finally got back on solid ground i noticed my bars were terribly turned to the right with the skis fairly straight but neither tie rods look bent on outsides. any ideas where my prob may be?
xt_gt
are they bent maybe? also the toe may be outta wack, but then that means something is bent i guess.
double check all front end parts.
rowdy_1851
i havent dug in to see if something internal got bent externally i didnt see anything i was checking toe but i have so much spindle slop i dont know what to go with.
woolyviper
- Mar 24, 2006
- hibbing,mn
- 2009 Yamaha Phazer RTX
there's a bracket on the frame over the engine - it would be the first joint from the steering post - i've bent this before and had the same thing happen - if you look at it you won't be able to tell unless you have an unbent one to compare.
