newfie09xtx
- Jul 13, 2011
- Corner Brook, NL
- 2016 Polaris Switchback 800 Pro S
Has anyone done this on their nytro? Would be interested in seeing pics if someone has.
raginyamaha
I have seen it done before, looks pretty good. im actually thinking about this myself....
radianguy
- Jan 1, 2007
- 2009 Yamaha FX NYTRO XT Express
me three
yzviper366
furg69
Wouldn't mind seeing this done myself. Won't be trying it this season as my sled is in a thousand pieces lol
herndonp
Tunnel coat
I sprayed mine this summer with (Between the Line designs) tunnel coat. I used a spray gun (air) and it took me a little over an hour, do to the thickness of the coating and trying to get a good coat on everything. I spent a lot of time cleaning and ruffing up with a scotch brite pad and then wiping down with acetone. I then taped up everything to prevent spray on bolts, nuts and exhaust system. The stuff came out great and feels like the Teflon in a frying pan.
Pete
Pete
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
pay2play
We're you thinking on the underside of the tunnel or outside of the tunnel?newfie09xtx said:Has anyone done this on their nytro? Would be interested in seeing pics if someone has.
Nytrokid28
I Just Put a carbon fiber wrap on mine i really like that but my brother was thinking of spraying bed liner on his nytro what kind were you thinking of spraying
newfie09xtx
- Jul 13, 2011
- Corner Brook, NL
pay2play said:We're you thinking on the underside of the tunnel or outside of the tunnel?newfie09xtx said:Has anyone done this on their nytro? Would be interested in seeing pics if someone has.
I was thinking the outside of the tunnel. While polishing looks good 2 rides in and your shine starts to go. Powdercoating would be ideal but ideal cost a lot of $$$ and more expertise than I have.
pay2play
Hmmm, never gave that much consideration. Polish is work, no doubt, but I like the bling!
pay2play
Re: Tunnel coat
Can you post a pic? I'd like to see the tunnel coat...herndonp said:I sprayed mine this summer with (Between the Line designs) tunnel coat. I used a spray gun (air) and it took me a little over an hour, do to the thickness of the coating and trying to get a good coat on everything. I spent a lot of time cleaning and ruffing up with a scotch brite pad and then wiping down with acetone. I then taped up everything to prevent spray on bolts, nuts and exhaust system. The stuff came out great and feels like the Teflon in a frying pan.
Pete
nitris223
- Nov 18, 2012
- Yorkton Saskatchewan
- Yamaha Nytro MTX
A buddy of mine did plasti dip. Looked good but started peeling after a bit. He didn't exactly baby it neither. Thought about that bed liner spray. Used the Duplicolor stuff on some quad racks and it sticks good. The only downside is that it is rough looking, not smooth. Dull in color like flat black. I think you can clear overtop to make it shine. I would stop at the running boards and not spray them. That's where his peeling started.
Tyloooor
I just bought two cans of plasti dip last night......will post pictures when done...
herndonp
Tunnel coat
I'll try and get a picture and post. The tunnel coat is for inside the tunnel(to help prevent ice buildup). They also make a tunnel coat for outside (running boards etc.)
Pete
Pete
