michawye
Help!!! I installed the Heavy Hitters (Speed Shop furnished) with the K & N Filters last season. Man; what a difference! No problems until I smoked a belt 2 wks ago. Spare I had was incorrect (way too big) but it was way too cold and far too walk back so I used it. Bad choice. Belt wore grooves in both clutch sheaves. Ok. Got new sheaves installed but mechanic can't get stock belt to set properly on secondary clutch with out squealing. Question: On the 04 Warrior, is a belt size other than stock recommended when using the HH set up? If not; has anybody had a problem with the engine moving??
