ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
RAMSOMAIR
Just ran Timmins/Cochrane/Gogama area for 3 days and put 1000 flawless kms on!
- Nov 11, 2016
- Cedarville, MI
- Cedarville, MI
The reason your belt is squealing after putting on a new belt is because the stock 8JP belt itself is a shorter belt to begin with....meaning if it is new (which means is a little wider), you will not be able to get the belt to the top of the sheaves.
RAMSOMAIR
I just didnt have the BOP adjuster backed all the way out. Belt is now at top of sheaves where its supposed to be!The reason your belt is squealing after putting on a new belt is because the stock 8JP belt itself is a shorter belt to begin with....meaning if it is new (which means is a little wider), you will not be able to get the belt to the top of the sheaves.
