bender rear mount help
heinracing
aberdeen sd
posting this for my younger brother
he has a 2003 rx1 with a bender rear mount
up in revy he picked up a boost leak
tracked everything down
the guy before him mounted the pre cooler with screws threw the tunnel into the top of the precooler whats the best way to mount this or do you put some thread tape on screws that are holding the precooler on?
any other areas to look for boost leaks? i put a pressure tester on the setup with soap and water didnt appear to find any other leaks
use good rivets, look at IC under hood,and at the carbs it pops off alot lot there.
