Bergstroms and pilots
marsh14
Liverpool, NY
I got my 8" triple points and it says to put a shim under the rubber for pilots. I am not sure if there is room. Is anyone running pilots, with slydog rubbers and triple points? Did you shim them or is that just for ski doos with pilots?
Hey marsh,
I have the 8" triple points with the pilots. I have a 3/8 shim that scott supplied with the carbides inserted in the rear of the bumper, however I am using skidoo rubbers that I purchased sperately.
I would just cut to the chase and give Scott a call. He is super accommodating and I doubt he would have a problem answering your question no matter what your set up is. Good luck. Kevin
I sent him an email but he didn't respond. If the spacer will fit with skidoo mounts, it should fit with the slydog ones. I will just get it out of the trailer and get it in the garage. I was just wondering if anyone else is running this combo before I tried it.
