uofm
I need the part # for the slydog rubber stoppers, i am also going to put my Yamaha loops on. The skis i bought are just the skins so will my bushings from my Yamaha ski loops work in the Pilots or do i need to order the Ski Doo bushings to make the loops work? This is for my 09 XTX
ShootToThrill
You have to trim the loops because they are a little to wide on the rear and the tip needs some trimming as well. Take a ski into the hardware store and find some stainless bolts to bolt them on. I used skidoo ZX chassis rubbers and they work well. I have the 5.7s but mounting should be the same.
larrypolaris
I had an extra mounting kit from my USI X2 ski's. That kit also works with the pilot ski's. You need to cut the bushings and spacers about 1/4" to fit in the ski and shim the rubber up so it fits tight against the spindle.
nytro addict
Try and google Slydog they have there own website or call Ulmers Racing he sells slydog's you can find him on this forum.
schoe
Yeah.. that makes sense... I tried to put them on this weekend.... And, I thought... I gotta cut this washer thingy too ?
From what I see... you got to
Cut the shims about 1/4 inch to get them in the ski
Shim the ski tips up a bit
use the new stopper
use the new stopper
marsh14
Just take out one of the ski bushings and put it on the outside. That's what i did.
- 6K
