dylanjen9
What is the best clutck kit for my apex er 121''. I mostly trail ride but also like to drag race other sleds. I would like good holeshot and still be able to pull away for others. Main thing I want to do is beat my buddy who has an apex ltx completely stock. He has one tooth smaller gear then me but a longer track so what should I do?
snowdust
- Oct 26, 2003
- Northern Illinois
- Sidewinder
Ulmer's and Sled-Werx both put out good kits. I found the Sled-Werx Trail Terminator kit to be the better of the two. It uses adjustable Dalton weights where the Ulmer kit uses super tips. The dalton's can be adjusted without taking the clutch apart.
shadow44
I don't think you will find a bad kit out there, they're all pretty good. What it boils down to it how much you wanna spend, how good of a tuner are you and what are you really looking to gain....as the wise Turk once said, " clutching is a compromise, you can't have it all ".
Some kits come with more components which doesn't make them better. I would do a search and read up on what guys have said about the popular kits out there. Are you a tuner who will constantly make adjustments or are you a " set it and forget it" kind of guy?
dylanjen9
I dont know much about clutch adjustment so I would probaly just set it and forget it.
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
That is the key,drop down one tooth on top,and add a set of differant weights,i have always ran my owne special clutch set ups i do myself,but allen has a good kit,dalton weights work good,i am using the old style dalton weights from a turbo,i cut down,and as long as you get things to shift out all the ways,and hold your max rpms for top,at around 10,600-11,000 you will run strong,and the smaller gear,will do nothing but help,it helps with your clutching as well.dylanjen9 said:What is the best clutck kit for my apex er 121''. I mostly trail ride but also like to drag race other sleds. I would like good holeshot and still be able to pull away for others. Main thing I want to do is beat my buddy who has an apex ltx completely stock. He has one tooth smaller gear then me but a longer track so what should I do?
dylanjen9
when you says change the weights what should I change them to. What do I have know the clutch is all stock and how hard is it to change weights.
Irv
- Mar 23, 2005
- ONT. Canada
1995 XLT SP (Son's)
nailsandrails said:Ulmer's and Sled-Werx both put out good kits. I found the Sled-Werx Trail Terminator kit to be the better of the two. It uses adjustable Dalton weights where the Ulmer kit uses super tips. The dalton's can be adjusted without taking the clutch apart.
Hoping to purchase a new Sled-Werx Terminator clutch for my Vector soon. He has had them for Apex's/Attack's and will shortly have them available for Vector's as well
blue er
I have ulmer stage 2 setup and it came pre set from allen and was pretty much bang on from the get go runs 10600 to 10900 rpm depending on ice conditions and hauls donkey.
your also almost always going to get beat by the long tracks out of the hole, cheap way out is the top year and the 20 dollar white secondary spring the long track uses
sledaddict
If you want a sure way to beat him every time you should change your track out for a deeper lug track. Put all your torque to the snow or at least more than your buddy that's the key 99% of the time. The clutch kit will only help if you take care of your track spin problems. Jmo.
Super Sled
- Feb 25, 2009
- Summit X
Heel clicker 2 speeds. I've tried many, this is the best by far in every way. Smooth as butter and pulls like a freight train.
