DANATTAK
Hi i am new to this site, i just got a new 07 attak gt, i want to stud it, i was thinking of up the middle with double backers, any tips (templates)?
TurboTime
- Jan 3, 2006
- Cassopolis, MI
- 2009 Yanaha Nytro
Welcome to TY!! There are plenty of posts regarding studding, you can do a seach and it will pull up plenty of information.
I am using 1.325 Woodys down the middle, good hook up, and no problems to the undercarriage.
zedosix
I would go with woody's 1.375 down the middle, at least 2 per row, thats 108 total I believe. If you are real aggressive maybe try a different pattern. Like 2 then three or three on each row. On the woodys' package you will find templates showing how to stud correctly.
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
most studs differ even with the same measurement..
measure from the underside of the head (sunk point to the tip...measure three different studs of the same quoted length and you'll get varying net lengths..
DANATTAK
studding
thanks for the info,i want to go only down the middle, i don't want to put any on the outside, i am sort of a hard rider how many do you think i should put on? i want to also only use double backers!
DANATTAK
i forgot to ask what size stud am i saposed to use and then what size do u guys say i should use, i don't need anything 2 long.DANATTAK said:thanks for the info,i want to go only down the middle, i don't want to put any on the outside, i am sort of a hard rider how many do you think i should put on? i want to also only use double backers!
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
woodys double / single or stud boy's patterns are good ....1.325's-1.450's...the 1.450's can hit the shielding a bit so look for posts shimming your protectors down..
attak-d
- Sep 20, 2006
- North Freedom,WI and Iron Belt,WI
162 down the middle . Doubles and singles.
