Skydog
Guys with all the new style weights, we can put weight right where we need it. But the thing i wounder about is it better to have weight on the heel or tip. You can load the heel max,middle all most full and leave the tip emty.
Or you can leave the heel empty the mid hole a little and load the tip. What is better and why? I know if you load the heel and mid it should grip the belt better right.
They say the heel is hole shot, mid is mid range and tip for top end. If you add weight to the heel it will bring down peak rpm.
How do you know if you have to much in the heel or middle hole?
Skydog
Skydog
Ted Jannetty
- Nov 24, 2003
- Waterbury Ct.
- www.jannettyracing.com
The biggest problem we have with all this power is grabbing the belt on take off.
So load the heel and mid and some in the tip for top end.
Here is good one for you, if you load the tip it raises engagement and slips the belt initially.
