bdm
Groomerdriver
richierich
same basic clutch.
the wrench method also works but unlike the tool it doesnt hold it open for you.
Groomerdriver
richierich said:same basic clutch.
Rich, I'll be ordering the tool from you in a few weeks.....after all the holiday shopping is done!
Artie2908
Rich, do you have a belt changing tool that fits the 08 Nytro? I have one from a 2005 Vector but it doesn't fit the Nytro. The bolt diameter is way too small. also will the tool for the 2005 vector work on a 2006 Apex? Thanks
change belt
I haven't tried this yet but I saw a friend do it and I couldn't believe how easy he made it look. He pulled up on the belt while turning the sheive which pulled it into and spread the sheives from the bottom then he flipped the belt off the top. It was almost embarrasing.
Geezer 2
Geezer 2
richierich
artie....i dont have one for nytro yet but i plan on making them.the tool will work on any yamaha sled 97 and newer except the 08 nytro and 07,08 phazer.
Artie2908
as soon as they become available I'd like one for the 08 Nytro. Thanks for the reply.
woolyviper
- Mar 24, 2006
- hibbing,mn
- 2009 Yamaha Phazer RTX
start by twisting the secondary and then pull up on the belt and that will aid in getting it open, once you get it going you will be able to slip the belt over the top of the sheave.
Groomerdriver
I used bdm's trick with the 12mm wrench and it was pretty dang easy to get the belt both on and off.
bdm
undecided said:I used bdm's trick with the 12mm wrench and it was pretty dang easy to get the belt both on and off.
I wish that I could take credit, it came from someone else here on TY, sorry I can't remember who.
JohnWI
RE: the box wrench technique:
If you're torquing it clockwise, isn't there risk of loosening that nut? Wait a minute...I suppose clockwise is tightening the nut, not loosening it. Duh!
06vectorgt
Always more than one way to skin a cat but I'm here ta tell ya - I love the tool method.
Groomerdriver
06vectorgt said:Always more than one way to skin a cat but I'm here ta tell ya - I love the tool method.
I'll still be getting one for sure......
k75
- Nov 24, 2005
- Bemidji, mn
- 2016 Vector x-tx
2006 Rage sold
Indy trail sold
Indy light - poor kids sold
Cat 340 - kids favorite, melted sold
1994 600 V-MAX sold
I like bdm have been using a 12 mm to remove and replace my belt on my 06 rage. The bolt does not seem to tighten in the process. I can hold the clutch open. Someone on this site mentioned the procedure.
