**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
there's only one product that works ...is cheap and is safe for just about every surface...
mineral spirits!
mineral spirits!
welterracer
colind said:wd 40 works also
I tried that first.. it wouldnt touch the stuff..
CaptCaper
- Jan 1, 2007
- Northern N.H.
sj said:there's only one product that works ...is cheap and is safe for just about every surface...
mineral spirits!
I've used that as well for years..
FLYBYU
theres a product called sticker off and another one called sticker on. http://www.hardlineproducts.com/stickeroff.html
Shivesy
WD-40 & Mineral Spirits isn't strong enough IMO. I use Turpintine and it works fast and doesn't harm the paint.
MUSKIE
- Dec 21, 2006
- SW Ont.
- Custom - 06 Apex
Rapit remover is the strongest stuff there is... O use in well vented area or you will catch a BUSS........lol good luck
GYTRules!!!
I removed the warning stickers from mine and my wife’s sleds. The first one I did was a royal pain. I rubbed and pushed the sticky stuff into balls then picked it off and repeated until it was all gone. Then I wiped it clean with a soft cloth. No fun! The rest were as easy as it gets. I peeled most of the sticker off and used the sticky back of the part I peeled off to sharply and quickly dab/blot the remaining sticky goo off. This worked extremely well!!! The first sticker took about an hour the remaining three took less than 10 min. I suppose if you didn't have enough sticky left on the part you peeled off you could use a good tacky tape with the same results.
Flitz!
schroon
- Mar 8, 2006
- Schroon lake, NY
- www.pacific-custom.com
I used alcohol,
