Best Way To Remove Sticker Goo???
there's only one product that works ...is cheap and is safe for just about every surface...
mineral spirits!
mineral spirits!
I've used that as well for years..
WD-40 & Mineral Spirits isn't strong enough IMO. I use Turpintine and it works fast and doesn't harm the paint.
Rapit remover is the strongest stuff there is... O use in well vented area or you will catch a BUSS........lol good luck ;)!
I removed the warning stickers from mine and my wife’s sleds. The first one I did was a royal pain. I rubbed and pushed the sticky stuff into balls then picked it off and repeated until it was all gone. Then I wiped it clean with a soft cloth. No fun! The rest were as easy as it gets. I peeled most of the sticker off and used the sticky back of the part I peeled off to sharply and quickly dab/blot the remaining sticky goo off. This worked extremely well!!! The first sticker took about an hour the remaining three took less than 10 min. I suppose if you didn't have enough sticky left on the part you peeled off you could use a good tacky tape with the same results.
