cmharcou
I weight 193lbs. dressed probably over 200. last year my Attak would constantly bottom out on the trails. looking for a spring that won't bottom out. It has gotten worst over the past few years of riding. Do I need a new shock rebuilt or the spring? or both? What part numbers do I need? Where do I get them at?
Irv
- Mar 23, 2005
- ONT. Canada
1995 XLT SP (Son's)
cmharcou said:I weight 193lbs. dressed probably over 200. last year my Attak would constantly bottom out on the trails. looking for a spring that won't bottom out. It has gotten worst over the past few years of riding. Do I need a new shock rebuilt or the spring? or both? What part numbers do I need? Where do I get them at?
Have you ever had the shock serviced or rebuilt? If not, then you're way overdue imo as that is more than likely the reason?
I am around 200Lbs dressed and I still have my shock set on the first clip! Have your shock rebuilt after you tell the rebuilder your weight and riding style and I am sure your bottoming out will disappear.
Definitely need a revalve/rebuild. The spring is more for ride height, the valving controls the ride. I personally like Hygear. If your shock has the stock valving, once you get it revalved, if will feel like you put in a different suspension
Nick1945
guardrail said:Definitely need a revalve/rebuild. The spring is more for ride height, the valving controls the ride. I personally like Hygear. If your shock has the stock valving, once you get it revalved, if will feel like you put in a different suspension
X 2
Newfie Apex
- Mar 3, 2010
- Mt. Pearl Newfoundland
- 2008 Nytro
spring
I had the same issues with my Apex..I sent shock out for a rebuild and whern reinstalled it I set clip in second groove and number three on the cam...I am 220lbs before dressing for the ride and I do not bottom out the skid since I have done this..
X3, except I went with pioneer. Very happy, and was cheaper. Really have no experience with others, but way better than stock now.Nick1945 said:guardrail said:Definitely need a revalve/rebuild. The spring is more for ride height, the valving controls the ride. I personally like Hygear. If your shock has the stock valving, once you get it revalved, if will feel like you put in a different suspension
X 2![]()
rbig18
- Mar 4, 2012
- SR Viper ltx se
x2 for Pioneer- Bruce will hook you up.
driftbuster
- Dec 12, 2004
- Wisconsin / Illinois Stateline
I went with Bruce at Pioneer last summer, and this last winter was the best riding (in a short period of time) that I can remember.
I weigh in at 230 dressed, and Bruce recommended the new spring along with the re-valve. Love my GT!
CaptCaper
- Jan 1, 2007
- Northern N.H.
I weigh in at 250lbs dressed and had Bruce at Pioneer put in a Big Boy spring and revalve and it made a big difference.
If you adjusted the C clip and Take up you'd be better but at the edge of needing the spring.
Call Bruce and tell him how much you weight etc. Yami has different size Big Boy springs.
