Pro-Stock
Been working on it for a few months off and on, Machined water passage and water inlet on the back of the block, Machined a deck plate, Drill and tap for longer studs. Thanks To Big Jim at OSP for the ideas and head studs. Waiting on stroker crank, rods and pistons. Thanks to Dave at Hurricane performance for those parts. Then I can send it out to get the bores plated. Cycl. head is done. Hopefully will be putting it back together in about a month.
https://www.dropbox.com/s/rgra5y49jkt22 ... .09.07.jpg
https://www.dropbox.com/s/3ca2i43iwq1w0 ... .17.24.jpg
https://www.dropbox.com/s/fs7i6v1dn0jwf ... .17.31.jpg
https://www.dropbox.com/s/v49u0k5mokgum ... .44.05.jpg
what kind of power do you estimate that piece of art will take?
nate007
- Dec 25, 2006
- Iowa City, Iowa
- 1. '06 Apex -twin screw
2. '04 Redline Revolt 800
3. '09 Nytro XTX - twin screw
Please add your location to your site profile, thanks.
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Lakselv - 70N & 25E
- Norway
Pro-Stock - welcome to the site
Wow that is some high presicion work you're doing. Looking great.
I assume the billett Block will be a lot stronger than the Stock cast Block.
Do you run the Stock head and bottom end?
Are you going With steel sleeved cylinders?
What powerlevel?
This is exciting!!!! Please let us know how she runs when done.
What powerlevel?
Pro-Stock
Not for sure on power really didn't build it to just turn up the power, build a about 3-4 years ago when there wasn't really a good block out. We are going to plate the cycl., no steel sleeves. Thought about it but just decided to plate them. Its a stock head casting with big valves, springs, and porting. Stock bottom case. There is more pics of the build on our facebook page. Thanks Paul
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Norway
Cool Paul
