Metallicat
Hi. I changed my chaincase oil after installing new gearing and chain and replacing all bearings last year. 1000 miles on the new gears and the oil is black, like used motor oil. I am using the Amsoil gear lube, which I have always used. Normally the oil is clear, with some bottom contaminates after a season of 2000 or 3000 miles. Is the condition of the oil a concern? With the gear change my chain tensioner whines a bit, like the Polaris Edge sleds, but I read that it is not uncommon.
titanrcr
- Jan 3, 2011
- Old Forge, New York
- 2019 Sidewinder LTX LE
2015 Viper LTX SE
2011 Apex
You may have the chain tension set too tight.
Metallicat
The tensioner is set correctly, quarter turn out. I backed it out to a half turn and the noise quieted down.You may have the chain tension set too tight.
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
- 2018 Sidewinder RTX
That discolouration has gotta be from breaking in the new parts. That is synthetic oil so it's one of the best lubricants for the job.
Ms
Ms
Metallicat
Ms
Maybe, but when the sled was new the oil looked ok even after 3000 miles. I filled it up with 8.xx ounces today.
titanrcr
- Jan 3, 2011
2015 Viper LTX SE
2011 Apex
If it were mine I'd pull the cover and have look.
Metallicat
Yes, good advice. I thought about the same. Then I thought about this winter....0 miles so far...it didn't blow up last year....gawd I'm just lazy anymore!If it were mine I'd pull the cover and have look.
R00STER
- Mar 3, 2013
- Timmins, Ontario
- 2013 Nytro xtx 1.75
If you replaced the upper bearing on the jack shaft, did the bearing have grease in it? That bearing is open to the chain case correct? I'm sure some grease in the oil would darken it up.
- Mar 1, 2004
Just DRAIN IT......seeing how you changed the upper bearing and adjusted the tensioner for the cost of what 6oz pour New Synthetic oil in and see what's up.
Flush it . I put in Trans fluid ,and take it for a rip .2 miles,better with a load , but if there is no snow , lift and spin track,then drain and put in gear oil.
ranger1
Like rooster said, if the upper bearing you replaced had grease in it, that would be enough to contaminate the oil. Change the oil & check it again
cnybrian
- Oct 6, 2011
- Cato, NY
- 2006 Yamaha Attak
- Cato, NY
Isnt Klotz chaincase oil black too?
4strokeluvr111
- Aug 27, 2011
- NW Wisc.
24K miles
Drain and refill with fresh
Metallicat
Upper bearing in the chain case isn't greased. Anyway, I changed and will keep an eye on it for sure.
But I like what tomanytoyz suggested and will flush it next time.
I might change the track next year anyway.
Thanks all!
Thanks all!
Dara
- Jan 24, 2007
- Sault Ste Marie, Ontario, Canada
Mine comes out black every year. 3000km a year on a 12 Vector.
One guy suggested it may be the tensioner plastic wearing off
