Bleeding cooling system
If you look just under the coolant bottle on the pipe you will see a black nipple. Remove it and add coolant to the bottle until coolant comes out. Install the nipple, start the sled and let the thermostat open. When the radiator is warm the thermostat is open. Refill the bottle to the correct level.
