WarriorWithin
Hi guys, the last couple of times I took my 08 rtx out the green drive light blinks for the first part of my ride then goes back to normal once it warms up. The are no codes displayed on the gauge and it seems to run fine, any thoughts? Should I be worried about this? I was wondering if it had something to do with the temperature as it was about -25 celsius my last couple of rides.
thought that was an indicator that the sled was stuck between reverse and drive...????
PattyJack
- Oct 9, 2008
- St. John's, NL
- 2007 Phazer GT
When mine gets stuck between reverse and drive the same thing happens, i just rock it back and forth and problem fixed.
OST
There were reports last season by a member "Gypsy roots" of the same thing happening to his sled.
Try doing a search of his posts ... there's lots, so it may take a while!
WarriorWithin
I checked out gypsyroots previous posts and they never really found what the problem is (or if there is one?). My sled still runs fine so I'm thinking it just blinks because the sensor is cold because it blinks for the first 5km's or so then is fine. Could I be doing any damage to the chaincase by riding it while the light is blinking? There have been no adjustments made to the chaincase and the fluid was changed about 1000km's ago. Just trying to see if I'm good to ride it as is.
Thanks guys
Thanks guys
