duck57
I have an 05 vector i blow a belt about every 700 to a 1000 miles haven't done anything with the clutching it is running the correct rpm . will a clutch kit help?
Groomerdriver
duck57 said:I have an 05 vector i blow a belt about every 700 to a 1000 miles haven't done anything with the clutching it is running the correct rpm . will a clutch kit help?
must be something wrong in there..have it checked out..
number1kyster
i have the same exact problem wit hmy 05. I blew a belt on my last trip. i have 4100 miles on it and i have blown 4 belts. This is more than any sled ive ever seen!!! Let my know if you figure out what it is. I think its clutch alignment.
MedoraRage
My current belt has lasted nearly 3000 miles.
A couple things to avoid are:
1. Trying to take off with the parking brake engage! Doh!! (ruined the first belt that way)
2. Driving at over 8000 rpm for an extended amount of time. I shredded a belt after about nearly 20 continous minutes of trying to go 90+ on powdery trails. I've read that belt durability sucks above 8000 rpm, one of the reason a pre-clutch reduction gear was added to the RX-1.
06rsvectorer
- Apr 11, 2005
400 trouble free belt miles on mine, clutchs are staying cool, belt shows no wear, and clutch has very little rubber marks on it
