cvenne
- Feb 6, 2006
Have an 03 rx1 and i am blowing the fuse that runs the speedo/taillight. I replaced the headlights at the start of the season with Xeon 100/80 bulbs from royal distributing and then the issue started. I then bought the LED taillight replacement bulbs since they draw much less than the regular bulbs but just the other day i blew the fuse again. I assume it is the headlights that is doing it but i really don't wanna give up the brightness that the new headlights give.. Any suggestions?
Thx
Thx
SIMMER
On the 2003's I was told by a reputable source at Yamaha Canada that there was only 30 Watts extra in the system to play with. Add a heated shield to that equation and your already over with those bulbs.
Stick with the stock wattage and you will be fine.
LABRADOR WARRIOR
- Jan 26, 2006
- Churchill Falls ,NL
- 2015 Viper MTX
I have a 04 Warrior LE ,mine keeps blowing the same 10 amp fuse but I have my heated visor tied into my hotgrips under bar pad.checked out all of wiring for wear or cracks everything ok evened OHMed the wires for continuity check..everything ok.Is there anyone else experiencing this problem..Becomes a big pain when out boondocking in -25 to -30 celc.and the D@#N fuse blows
cvenne
- Feb 6, 2006
Well i guess i will have to go back but those bulbs are garbage compared to the Xeon ones....Oh well....
Thx
Thx
Try the silverstars, same wattage as stock, nice and bright!
cvenne
- Feb 6, 2006
where can i get those in Canada?
SIMMER
LABRADOR WARRIOR said:I have a 04 Warrior LE ,mine keeps blowing the same 10 amp fuse but I have my heated visor tied into my hotgrips under bar pad.checked out all of wiring for wear or cracks everything ok evened OHMed the wires for continuity check..everything ok.Is there anyone else experiencing this problem..Becomes a big pain when out boondocking in -25 to -30 celc.and the D@#N fuse blows
Take the power from the high beam switch (blue wire with white tracer) instead of the heated grips. Your not rerally supposed to tap into the heated grips (brown wire?). Causes problems with the CDI.
Ebay or wallmart has them if there is one in Canada.
cvenne
- Feb 6, 2006
Ya we have Wally World.. hehe...Thanks.... I see the other post about the wiring but just swapping out bulbs seems much easier.
Thx
Thx
cvenne
- Feb 6, 2006
Do you know the model/part number so when i go there i know i have the right one?
9003 ST, just put a set in my Warrior. Now my buddies are all getting them if that tells you anything.
cvenne
- Feb 6, 2006
So how much brighter are they than the stock?
LABRADOR WARRIOR
- Jan 26, 2006
- 2015 Viper MTX
Thanks RXWonder
I'll try this setup.My heated visor was hooked up by my dealer?????
hopefully this works .I need to get that visor working again .
I would say the silverstars are 2-3 times brighter than stock. Nice white light. even at idle. superior over stock. As much money as we pay for these sleds they should come from the factory, you can't put a price on satety!
