freelheeler
i need a little help
my rx1 non boosted has been bogging like an SOB, and i'm not sure of a fix? here's a bit of info, 03 rx1, under tunnel exhaust, 18/40 gearing, 162 track. the sled runs strong till i get into powder.
last weekend in somewhat deep snow at around 9500 elevation it seemed to be starving for air and would bog and burble, i'd clean off the vents and it'd clear out a bit till a wave of snow hit it again or half way up a climb. heading down the trail a little lower in elevation it ran strong.
so i put filter fabric over (aka panty hose) over all the vents and the air intake for the air box. well i went out yesterday and it wouldn't even pull 8500 rpms so over the course of the day i removed all of the fabric. the snow was real deep up high and around 9500-10,000 it ran like crap, i'd look at snow and it'd start bogging, get it out on the road and it'd pulled hard.
i've got it jetted for about 8000-9000' and i've thought about re-jetting and going thru the carbs but i have almost pin pointed it to snow/air intake. my thought was the less restrictive exhaust maybe causing it to run lean or rich? but i'd think it perform poor on the roads as well as powder if it was jetting? the burbles have been a persistant thing where as the bog seems to be on big powder days? i had plans of boosting the sled but if i can't get it to pull hard in powder w/out boost i don't want to waste more time and money, this ain't a trail machine and i need to get it dialed
what have folks with the turboed rx1's done to deal with this issue, i've heard the k@n doesn't seem to help that much? different hood desgins? snorkel systems? fan? i looked at holes behind the windsheild but it has pretty good holes already?
thought/commets thanks
