legend
I have installed a bd turbo. I ride alot of trails in Northern Ontario where noise really isn't an issue. If I dump out bottom of belly pan with exhaust could I put a supertrapp on the exhaust to quiet it down? Or will that hurt performance or the turbo?
TurboJamie
legend said:I have installed a bd turbo. I ride alot of trails in Northern Ontario where noise really isn't an issue. If I dump out bottom of belly pan with exhaust could I put a supertrapp on the exhaust to quiet it down? Or will that hurt performance or the turbo?
Your kinda screwed with that side mount, you might be able to bore a hole though the side of the tunnel like the bender does to bring their charge tube forward and run your exhaust out the rear with muffler.
legend
i can get a super trapp that will fit . but i need to no .if it will hurt anything as like the turbo. or lots of perfomace thanks
Super trapp will work fine, I am going to be running one myself. With a turbo you really don't need a muffler, Turbos hate back pressure. But you need something to quiet the noise.
TurboJamie
I agree tops loss would be 5 - 10 hp with a good freeflowexhaust.
