pedros83
- Nov 19, 2015
- Blackstock, ON
- 2010 Nytro XTX
Installed this kit in my nytro. BPS G2 led conversion designed to work in halogen reflectors. 100watt. And "claimed" 16000 lumen output. The lights are a massive upgrade from stock with stock light cutoff for oncoming traffic. The bulb splits in 2 to utilize factory dust cover with no mods. Installed in 10min. Led has 2-6 pod emitters that face up for low beam and 1-6 pod facing down to add for highbeam. 50000hr lifetime and 2 year warranty. Paid $65 cad. Shipped to my door off ebay. Cheaper for you yankees. Lol
Look at this on eBay http://www.ebay.com/itm/252654627387
So this kit comes complete with everything, plug n play? Looks wicked.
SteelerJim
I have HID's now and would consider trying these out as the HID's aren't a huge improvement over stock in my opinion. The wattage seems kind of high though. I know the stator on the Nytro can't handle a lot of extra power drawing off it. Which is where the HID's shine.
pedros83
- Nov 19, 2015
- Blackstock, ON
- 2010 Nytro XTX
Yes kits plug and play. 50watts per bulb no different then stock halogens
Sent from my LG-H831 using Tapatalk
pedros83
- Nov 19, 2015
- Blackstock, ON
- 2010 Nytro XTX
So the led high beam actually uses less watts then 60watt stock high beam.
mtcooler
Them look nice. Should of have a before and after pic.
pedros83
- Nov 19, 2015
- Blackstock, ON
- 2010 Nytro XTX
I know i was thinking that after damnnn
mtcooler
That one pic looks like high and low beam are on at same time?
pedros83
- Nov 19, 2015
- Blackstock, ON
- 2010 Nytro XTX
The one with the trees on the side is low beam the one on the road is high beam
mtcooler
Just orderd a set! Have a hid upgrade kit in mine now but am not happy with them the cut off point for high and low beam are so far off low has to be on ground right in front of sled otherwise high beam is in the trees.
pedros83
- Nov 19, 2015
- Blackstock, ON
- 2010 Nytro XTX
That was the reason i never went the hid route. They are designed for projectors. This led mimics the shape and output pattern of the halogens.
mtcooler
Does the nytro run a B4 bulb?
pedros83
- Nov 19, 2015
- Blackstock, ON
- 2010 Nytro XTX
H4Does the nytro run a B4 bulb?
mtcooler
Will report back after i get them. Hope they look as good as yours! Sorry ment H4 Thanks for sharing!
pedros83
- Nov 19, 2015
- Blackstock, ON
- 2010 Nytro XTX
Shipping was super quick!
