br9ek question
revvystoke
Alaska
I have a new set of plugs to throw on, where do you guys grab the threaded tops for the spark plugs from?
The BR9EK's are threaded, and the older plugs I have all have solid tops. Can I order them separate or do I have to buy new plugs and rob the tops off of them.
I thought thease were cr9ek's you can rob them off any plug.
TBay Sledhead said:
B is a 14mm thread C is a 10mm thread so I don't think the B's will fit.
Sorry they are CR's, I had a set of br's on the table I was trying to unscrew caps from.
If the B series plugs you have have solid terminals then you will need to buy different plugs with removable terminals.
