miked
Has anyone noticed when you pull real hard on the brake lever, the brake light goes out. My brake light comes on when I pull the lever, but when I pull real hard the brake light turns off. Bad switch?
gerard143
my switch #*$&@ the bed.
gerard143
acted weird then pretty much totally stopped working
chrispyxx
I was told by people i ride with dont you use your brake ? Maybe mines not coming on? I found I don`t use it alot because of engine breaking.But when I do use it i`m in deep to the corner and I usually lock the track.I will check mine when im in the garage next & post the outcome.
Roswell
I was having problems with mine after a wash without a dry. The light would work after 30 min. or so of riding and be ok until cold again, found out there was moisture inside so I flushed out with silicone spray and has been ok since.
P.S. I removed the switch to do this
