blue06
took the secondary sheave off today to clean and regrease the 2 bearings, and noticed one of the buttons broken off. what would cause this and should i be checking anything else in the clutch before the season starts? by the way the sled is a 2006 attak with 9000km on it. thank you for any info.
baggs66
- Nov 18, 2007
- chautuaqua co. n.y.
- 06 apex gt
Usually happens when you get some air and come back down, clutch will kick back if you hook up hard and this will snap off the ramp. Not real common on stock clutch but have broken a few rollers off my roller clutch.
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
Can happen when reinstalling the spring too.
Change all 3 buttons at the same time.
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
When was the last time u check them.
blue06
i never really checked them before, i noticed it when i took the side panel off and found it in the bottom. going to the dealer to pick up three new ones. the dealer said they can dry out and crack after a few years ? thanks for the replies , i'll start checking them more often.
APEX 06
- Apr 30, 2009
- Sheboygan, WI
blue06 said:i never really checked them before, i noticed it when i took the side panel off and found it in the bottom. going to the dealer to pick up three new ones. the dealer said they can dry out and crack after a few years ? thanks for the replies , i'll start checking them more often.
X2, they last about 3000 miles
- Nov 1, 2009
- Winnipeg, Manitoba
- 2009 Phazer RTX
APEX 06 said:blue06 said:i never really checked them before, i noticed it when i took the side panel off and found it in the bottom. going to the dealer to pick up three new ones. the dealer said they can dry out and crack after a few years ? thanks for the replies , i'll start checking them more often.
X3, I check them every year when I wash my secondary.
black knight
how hard are they to change. any special tools?
- Nov 1, 2009
- 2009 Phazer RTX
They are not hard to change at all. Page 118-120 in the Apex service manual.
LJ 452
Easy to change, should be done every 3000 miles if aggressive, maybe 5000 if not. DO NOT USE THE CHEAP MARSHALL ONES. They are not the same material and all break off, resulting in a tower breaking and thus you are out a clutch, or at least half of one. The Yamaha stock ones are EXPENSIVE so prepare (as always) to bend-over when you buy.
You will want to inspect the clutch where the button rests against it. Busting one can cause stress on the others and crack the clutch in this area.
I have sold dozens of clutches because of people boating the helix on without holding the clutch spun open.
arcticace
I broke one of mine when the drive belt snapped, found one had cracked in half.
