Secondary clutch slide buttons
danman62
Saint John, NB, Canada
Has anyone else have the part of the clutch crack ,that holds the slide buttons. All three of mind are cracked. I noticed mind when I was checking my clutch and one of my slide button was broken off.
i lost a tower on my secondary the same way. happens when you do not let the engine braking start 1st before you grab a handful of brake.
They usually break if you change the secondary spring rate or change the helix, I gave up and bought a roller secondary
