broken warrior speedo
jr3
northern vermont
My speedo on my 04 warrior quit working this weekend.It reads zero most of the time or it will start to read random numbers which change at a rapid rate. The odometer is acting the same way , normally doesnt add the miles but will occasionally add a few.Any ideas?
Don't ride the sled again until you check the clutch side drive shaft bearing. Its a common failure and the speedo drive pickup is mounted to the driveshaft right in front of the bearing. If the bearing comes apart it cleans out the speedo pick up, and potentially the driveshaft and/or bulkhead around it. Check it ASAP!!!
I'll Second that!
