northernguy10
i have an opportunity to purchase a nytro xtx with a seize motor. that easy! but is there any other gremlins that i should look out for?
any help is appreciated
marty
marty
sorenson1610
- Dec 11, 2007
- Rothschild,WI
- www.contrx.com
You know why it seized? Are you rebuilding or buying a used motor to drop in? How much you buying it for?
Roost 'Er
Any chance its a 2009 with around 9k on it?
northernguy10
o k spill the beans I have ways of making people talk
Roost 'Er
lol i found one with a seized motor im thinking of buying the skid out of for my RTX, just wondering if it was the same one. The one i saw is Greater Toronto Area though.
DelgatyXTX
A seized motor in a 4-stroke is a lot more money and a lot more work than a 2-stroke. I'd plan for the possibility that the motor may need to be swapped out and is irrepairable, which will run you $3000 average. Whatever the sled would be worth if it was in perfect running condition, don't pay anymore than $4000 less than that.
The XTX is a great sled but if it has a lot of miles you'll also have to replace all drive bearings, ball jounts, bushings, exhaust donuts, lots and lots of work. It would however be a great project if you have the time and money. If it's got a lot of miles but the chassis is still straight and true, it would be fun to tear it right down to the frame and completely re-assemble with new hardware and do alot of customizing while you're at it.
