rxwhopper
did a search with no luck. can i put a 1 3/4 back country track under mt attak with 9 tooth extroverts and keep the skid in stock location. Is there any mods. i think this is the track i need for the supercharger
Gibby
- Jan 28, 2005
- Jackson, Michigan
- www.fitzgibbonstruck.com
have to remove the protectors on the front heat exchanger and the tunnel if it is the same as the 05 warrior which i do believe it is
Yamaha Man
I have a 1.75" track on my Apex and it worked fine. All you need to do is take off the tunnel protectors.
Turk
Tech Advisor
Lyle
no probs. Great track to harness your 200 hp.
